Rot!
- SHAFT666
08 Jul 2020 11:37 #224681
by SHAFT666
Rot! was created by SHAFT666
Discovered some major rot yesterday, usual spots like sills and boot floor but the worst of it being around the body mounts. Is it possible to buy new body mounts to weld in and if so where from? If not whats my best option? Also heavy corrosion on brake and vacuum lines so any links to replacement parts much appreciated.
- Reason2doubt
08 Jul 2020 11:59 #224682
by Reason2doubt
Replied by Reason2doubt on topic Rot!
Re body mounts: If they are really badly gone you could grab some of a different chassis otherwise they can be repaired (going off what others on this forum have done). I repaired some of mine and had a welder do the rest which I couldn't do.
Both sills, both rear arches, both back body mounts and back body structure cost me £600, for price reference.
08 Jul 2020 13:53 - 08 Jul 2020 13:57 #224683
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Have you tried BigJimny shop?
Martin might be able to get what you need as sometimes he stocks part like this (just an example)
bigjimny.com/store/rear-coil-spring-bracket.html
Alternatively contact 'suzuki cars uk official' ebay seller directly.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 08 Jul 2020 13:57 by HUN.
The following user(s) said Thank You: SHAFT666
- SHAFT666
09 Jul 2020 23:46 #224745
by SHAFT666
Replied by SHAFT666 on topic Rot!
2007 and low mileage, not sure what kind of life it previously had but outwardly was very clean when I bought it last year.
