3" pro comp shocks
- Scot The Sniper
- Senior Member
- Thank you received: 4
6 years 4 months ago #224512
by Scot The Sniper
3" pro comp shocks was created by Scot The Sniper
OK guys some help is there anywhere else I can get 3" Pro comp rear shocks from as big Jimmy bits are not getting them in till Aug sometime grr. So I'm stuck with new springs on the front with 3" Pro comp shocks have the rear springs ready to be fitted all I need is the shocks.
6 years 4 months ago #224513
by 300bhpton
Replied by 300bhpton on topic 3" pro comp shocks
Do you know the part number? Lots of Pro Comp stockists. Although many many be Land Rover places. But if it's a shock that fits other vehicles. Might be worth a call round, such as Paddock Spares.
Llama4x4 stock Rough Country shocks. He might have a direct alternative on the shelf.
- Thank you received: 706
6 years 4 months ago #224517
Replied by jackonlyjack on topic 3" pro comp shocks
I run pro comp shocks ES1000 fronts are fine rears are way to stiff
Also think the 1000's are no longer available so you get offered ES3000-9000's which are even stronger valved
These are more suited to jimny with full roll cage and heavy steel bumpers.
- Scot The Sniper
- Senior Member
6 years 4 months ago #224551
by Scot The Sniper
Replied by Scot The Sniper on topic 3" pro comp shocks
Hi Jack with not knowing much about all of this I went on to Jimmy bits and the only ones they had for a 3" lift were the pro comp ones es3000 so I bought them and was just gonna match them up on the rear?
6 years 4 months ago #224554
It all depends on what you're planning to do/go with it
Rough country,trial master are not cheap.
Vitmods sells cheap ones possibly vauxhall astra, Vectra ect with bush sleeve modified.
Also Jimny bits raptor are more suited to standard weight Jimny
Lots to choose from lol
6 years 4 months ago #224560
vitmods ebay item number 184331536395
If you don't like em i will buy them off you
