TPS help
6 years 4 months ago #224144
by Old Neil
Replied by Old Neil on topic Re:TPS help
Looks like i was barking up the wrong tree, tested TPS a number of times, hot, cold when motor was running rough, always tested. 37v at idle to 3.70v at full open throttle but haven't been able to find out if that is in speck, had manual on computer but that died, couldn't find anything on Google
6 years 4 months ago - 6 years 4 months ago #224167
by Scimike
Replied by Scimike on topic Re:TPS help
Just posted this in relation to a different question. No voltage given as it should in theory record a DTC code if failed. However they do have a resistance check between pin 1 and 3 - 4 to 6kohm. Between pin 2 and 3 variable between 0.02 - 6kohm. This is according to my manual, doubt it's changed much over the years
Mike
Mike
Last edit: 6 years 4 months ago by Scimike.
6 years 4 months ago #224173
by Scimike
It's possible they did change over the years, so the above information was via a manual for the following chassis numbers.
SN413
JSAFJA43V001 4XXXX
JSAFJB43V001 4XXXX
JSAFJB43V201 4XXXX
JSAFJB43V241 4XXXX
JSAFJB43V341 4XXXX
Outside of these chassis numbers it's not the correct manual, so confirmation may be the best route just incase they changed the device.
1 to 3 is the resistor and is not variable, so the reading should not change, irrespective of the value. It could be your test leads are not making a good enough connection. 2 to 3 is the variable value and will change with TPS position.
SN413
JSAFJA43V001 4XXXX
JSAFJB43V001 4XXXX
JSAFJB43V201 4XXXX
JSAFJB43V241 4XXXX
JSAFJB43V341 4XXXX
6 years 4 months ago #224205
by Old Neil
Oops YouTube shows different way to test TPS, looking like i have to retest, thanks
6 years 4 months ago #224206
by Scimike
I believe you can measure the voltage as well, I remember seeing this but can't find details at the moment. I will have another look tomorrow, but you can check the TPS as a stand alone device by it's resistance.
Mike
Mike
The following user(s) said Thank You: Old Neil
Time to create page: 0.084 seconds
