Differential gears
6 years 4 months ago #223830
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Differential gears was created by HUN
Are the ring and pinion gears of front and rear differentials interchangeable? Are they the same size? I'm wondering if a worn/damaged diff could be temporarily fixed with swapping those parts from the other diff.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
6 years 4 months ago #223837
by Busta
Replied by Busta on topic Differential gears
No. The front diff is a high pinion design and the rear isn't.
6 years 4 months ago #223850
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Replied by HUN on topic Differential gears
Thanks Busta!
I was thinking about this option as they serve the same purpose with identical ratio in the same car. It would make sense to me keeping things simple...never mind. Has to be a good reason for this design.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Time to create page: 0.074 seconds
