Re:Spring squeak
28 Apr 2020 18:37 #221615 by facade
Replied by facade on topic Re:Spring squeak
Most cars have them, I thought their job was to hold water and corrode the last half turn of coil so it snaps off ;)
Plenty on eBay in different sizes- look for Tein spring silencer.
29 Apr 2020 07:44 #221635 by kirkynut
Replied by kirkynut on topic Re:Spring squeak
Perhaps rotate the spring a little and see if it stops. I believe we have the same springs and mine are silent.
02 Aug 2021 15:00 #237261 by DrRobin
Replied by DrRobin on topic Spring squeak
My 2011 has a squeak from the front passenger side, but only when I press or lift the front nearside wing.
I have tried opening the bonnet, in case it was the bonnet bushes, but the squeak remains.
Is it likely to be the front passenger side spring rather than the panhard bush, if it was the panhard bush, wouldn't it squeak if I pushed both sides up and down?
I am sure it has only just started doing this in the last month or so, I could spray some grease in there to see if it stops?
  • giov19
17 Jan 2022 07:26 #241246 by giov19
Replied by giov19 on topic Spring squeak
My 2019 has had the same issue.... Drove me insane, lubricated everything underneath with no success. One day I was standing in front of the car when my son shut the door.... Revelation!! It was the bonnet bushes!! Popped up the bonnet, turned the two bushes to get them higher and problem solved!!
