Gen.4 Jacking Advice
- Thank you received: 96
25 Apr 2020 17:29 - 25 Apr 2020 17:36 #221489
by DAGZOOK
Gen.4 Jacking Advice was created by DAGZOOK
Evening All,
I've invested in some Buzzweld Chassis Paint & Bilt Hamber UB wax with the intention of going to town on the undersize of my 12 months old JIM. I've done similar jobs before on old sports cars with great success.
I'm trying to figure out the best way to get as much access to the underside as possible on my flat driveway.. I'm prepared to purchase some new kit to enable me to do this because of the additional jack height required with a 4x4.
Ideally I want the axles to be fully dropped, to give me as much access and hand space underneath the JIM. So to do this I need to figure out the best points to jack the frame up. I managed this just about when I installed my ARB breather kit, but it was a real struggle with the current trolley jack that I own. I also found that because the JIM has such a short wheel base - if you jack from one of the lowest frame points (just behind the radius arms) the vehicle doesn't feel stable.. it feels like a seesaw! Little too close to the vehicles fulcrum for my liking.
The crossmembers at the front and rear of the vehicle are approx. 500mm off the ground, so even a high lift bottle jack won't touch them unless I place a couple of sleepers beneath the jack.
I do own a set of tall drive on ramps.. but as previously mentioned I need the axles to droop in order to get to every nook and cranny!! OHHHH how I wish I had a garage big enough for a 2/4 poster :woohoo: :blink: :silly:
Can anyone recommend some clever gear to enable me to do this? I'd like to be able to lift the whole front/rear independantly opposed to going from corner to corner. I've been looking at high lift bottle/trolley jacks - Tall Axle Stands, Possibly even a Trolley jack with a beam attachment?! etc etc. Budget is around £100 - This'll pay for itself over the duration of my ownership - A good clean/inspection annually will be just the ticket.
I've been looking at SGS - they seem to offer a very large variety of gear.
www.sgs-engineering.com/garage-equipment
Last edit: 25 Apr 2020 17:36 by DAGZOOK.
The following user(s) said Thank You: Bill Portland
- Bill Portland
- Thank you received: 77
25 Apr 2020 17:37 #221490
by Bill Portland
Replied by Bill Portland on topic Re:Gen.4 Jacking Advice
I'm interested to hear responses to this too. I've also been trying to find a local garage that'll let me use their lift, but with no luck so far.
- Thank you received: 706
25 Apr 2020 17:47 #221491
Replied by jackonlyjack on topic Re:Gen.4 Jacking Advice
Halfords sell high axle stands
I use four ramps select 4wd low and drive up (very safe option)
Jack
Jack
25 Apr 2020 18:00 #221492
Just read through your post
This option works 4"x4" fence post across the chassis rails(sawn to take the shape of axle stand)
remove front bumper and put axle stands under where the bumper mounts
Then 2 more axle stands on rear chassis near tie downs
so 6 axle stands needed
I have used this method and it's not has bad as it sounds
i even tried to push the jimny off the stands before i went underneath
The following user(s) said Thank You: DAGZOOK
25 Apr 2020 18:14 #221493
by DAGZOOK
Replied by DAGZOOK on topic Re:Gen.4 Jacking Advice
Thanks Jack Only Jack - I've got some long off cuts of railway sleeper from a landscaping project. Thats certainly an option!
Getting the car up in the air isn't the problem - I can jack from the axles. It's supporting vehicle once high enough that's the issue. Timber and a high set of jack stands front and rear sounds good. Like I said, so long as the axles are fully dropped once supported I'll be happy.
- Thank you received: 2004
25 Apr 2020 18:18 #221494
Replied by Lambert on topic Re:Gen.4 Jacking Advice
I have a set of 4 Clarke 6 tonne axle stands that extend up to 600mm. These allow me to position them under the chassis and have full droop with the wheels on. While it does mean groveling about on the floor instead of being stood up it affords ample space to be thorough with the rust prevention.
Time to create page: 0.099 seconds
