Eau de essence( Benzine)
There is a breather pipe running to a charcoal filter under the bonnet, this has a one way valve somewhere so you can blow down the pipe into the tank, and it holds a low pressure. If the tank over pressures vapour comes along the pipe and is absorbed by the charcoal. When the engine is started the filter is purged through a valve on the manifold. Overfilling the tank sends liquid fuel to the filter, makes it smell, and causes rough running for a few seconds after start-up.
Do check all 3 pipes from the tank, they have a habit of rotting through just under the drivers feet where they kink upwards along the chassis. A pinhole will leak enough for a lot of smell.
- Max Headroom
- Banned
- Thank you received: 216
I've very occasionally had rough-rounning after initial start-up and an occasional fuel smell - but there seemed no real pattern to it.
But with your explanation in mind I will make a concious effort to determine if this is after I fill the tank as I do have a habit of filling it to the brim. It may be that the fuel coming out of the cold ground-tank may warm up in the car's tank, expand, and thus overfill.
The tank is made so there is an air space at the top, which is an expansion space for the fuel as it warms up. This works nicely if the car is level when you fill the tank
If you keep trying to fill the tank after the pump cuts off, and shake the car etc.
The valve in the tank is supposed to stop liquid fuel flowing from the tank to the EVAP filter, either it wears out, or more likely it is made to give in extremis, otherwise the tank would burst, or the filler pipe come off.
If you must squeeze every last drop of fuel that you can into the tank (I used to do this) you need to immediately drive the car a few miles to use up the "extra"
If you blow down the tube from the EVAP canister to the tank (with your mouth, not an air line), you can pressurise the tank, and get a "hiss" if you immediately open the cap. In normal use as fuel is used up air enters the tank via a valve in the cap, this is sprung so it takes a little negative pressure to open, and you often get a hiss- ( or should it be a ssih
facade wrote: you often get a hiss- ( or should it be a ssih
That right there cracked me up lmao!
