Re:Re:Washer pumps performance
  • TillymintDLG
17 Apr 2020 11:47 #221159 by TillymintDLG
Washer pumps performance was created by TillymintDLG
Hi Guys & Gals, how's solitary suiting you? I am wondering whether the W/Washer pumps can be cleaned/serviced?
My Drivers side jet is as normal but Passenger side and rear screen jets are very poor...
I have just given said a good rodding and no improvement!
Any suggestions?
Cheers
Gaz
17 Apr 2020 18:48 #221168 by RainerK
Replied by RainerK on topic Washer pumps performance
Hello Gaz,
You could clean the nozzle and the hose and install a small inline filter. Over the years there might be a build up of dirt in the system and the dirt the blocks the nozzles.
The following user(s) said Thank You: TillymintDLG
  • TillymintDLG
17 Apr 2020 20:29 #221176 by TillymintDLG
Replied by TillymintDLG on topic Washer pumps performance
Thanks for the reply Rainer, I have done that and they seemed ok!
I have seen pumps on Ebay for £12-15 so might get one and just try a straight swap...my rear wash is only just reaching the bottom of the window!
Gaz
17 Apr 2020 20:31 #221177 by mlines
Replied by mlines on topic Re:Washer pumps performance
Also change the inline non return valve, this is usually the cause of most issues
  • TillymintDLG
17 Apr 2020 22:23 #221178 by TillymintDLG
Replied by TillymintDLG on topic Re:Washer pumps performance
Thanks for the reply Martin...
Is that No.14 on this diag?
www.megazip.net/zapchasti-dlya-avtomobil...ad5-68339/n-a-487289
Gaz
18 Apr 2020 05:27 - 18 Apr 2020 05:30 #221183 by mlines
Yes, really cheap. Only a couple of £ even from Halfords. Less than that from a lot of places
Last edit: 18 Apr 2020 05:30 by mlines.
Time to create page: 0.109 seconds
