Gen4 Jimny Service manual
  • warrengti
  • Visitor
  • Visitor
06 Apr 2020 02:19 #220745 by warrengti
Gen4 Jimny Service manual was created by warrengti
Hi does anyone know if there is a service manual avilable for the Gen 4 Jimny ?
or wiring diagram ?
I am looking for Acc trigger wire and Illumination wire
Thanks
06 Apr 2020 07:40 #220746 by crash486
I've seen people use the 12V plug in the dash as an accessory trigger.
I had a loom made for my spot light switch which included an illumination feed. I believe they tested the wires to determine what was what.
Sorry I don't have any better info.
crash486
06 Apr 2020 09:30 #220748 by Soeley
Replied by Soeley on topic Re:Gen4 Jimny Service manual
Hi Crash, where did you get the switch from? I managed to get THIS ONE it blue illumination, I have been meaning to take it apart and see if I can swap it to amber LED to match OEM.
07 Apr 2020 05:06 #220767 by crash486
Soeley wrote: Hi Crash, where did you get the switch from? I managed to get THIS ONE it blue illumination, I have been meaning to take it apart and see if I can swap it to amber LED to match OEM.
They are Toyota short switches. Should be able to find them closer to you than Australia where I got mine.
You choose a base and a cap to suit what you like.
qled.com.au/index.php?route=common/home .
crash486
07 Apr 2020 21:06 #220793 by Soeley
crash486
Thanks, I'll look into it.
  • warrengti
  • Visitor
  • Visitor
10 Apr 2020 06:34 #220881 by warrengti
Replied by warrengti on topic Re:Re:Gen4 Jimny Service manual
Thanks every one
I do like the look of those switches that will be a mod im going to do later im looking at an AFN loopless bar and I would put 2 x 7" led spots on the front.
Off topoic I guess but back to it after a scuseesful day of installing dynomat in the doors and body and upgradeing the speakers while I was in there. I used the pioneer 5.25" 3 way speakers unfornatley thse were not a direct swap like the 2 ways but not so bad to install bit of custom work with some MDF and waterproofing.
Tomorrow I any doing to try and install my under seat sub and my narva 12 was fused distrbution block this has 6 x power feeds and 6 x acc feeds and 12 earths. this is why I was looking for the ACC feed Anyway i will get the meter out tomorrow and check out what is under there. Might take photos of this one could be handy for people wanting to install a 2way or somthing after market that requires power.
Time to create page: 0.208 seconds
