Sport/gti engine to automatic box
- Mrgreg
02 Apr 2020 06:25 #220565
by Mrgreg
Sport/gti engine to automatic box was created by Mrgreg
Hi, has anyone fitted an auto with a 1.6 sport engine.
If so has the box stood up to the extra power.
Cheers Greg
Cheers Greg
- Thank you received: 227
02 Apr 2020 06:40 #220566
by zukebob
Replied by zukebob on topic Sport/gti engine to automatic box
Probably your best source to do some searching is on the Auszookers forum. I may be wrong but don't think anyone here has converted to the M16 with an auto.
I can only give some anecdotal feedback that came from Auszookers. The general consensus is that the autos didn't do well with the extra power of the M16. There are some direct comments about the damage seen with the M18. If you do a search without much to show for it, you can join and ask the question directly. If you do, the only warning that I would give is that you need to prepare to filter out responses that are based on a general prejudice against auto Jimnys.
- Thank you received: 2004
02 Apr 2020 06:40 #220567
Replied by Lambert on topic Sport/gti engine to automatic box
Not seen anyone that I can remember saying that they have been experiencing problems. The only problem could be heat buildup in the transmission fluid which just means adding a separate cooler to the lines to the oil cooler in the radiator.
- Mrgreg
02 Apr 2020 07:33 #220569
by Mrgreg
Replied by Mrgreg on topic Sport/gti engine to automatic box
Thanks for the quick response, just joined zookers and asked the same question, see what happens now. Cheers
Time to create page: 0.077 seconds
