Ring and pinion
- VITAC
6 years 7 months ago #220378
by VITAC
Ring and pinion was created by VITAC
Hi guys ... Does anybody know this pinion ring set. Is made in china and i have second thoughts as i don t know the manifacturer.
I have already placed a M16A motor that can easily run the 205/80/16 tyres. The problem is that the clunch already has a very hard time especialy in the city .This will go worse if i go to 235/70/16 tyres. So a reduction of 13% will be really ok. My vvt has a dif ratio 4.3 . So what this set promise i ll get this 13% reduction
Please check the link
#Aliexpress US $399.00 | Jimny Car Styling Front And Rear Final Reduction Gears Set 4.625/4.875 Ratio
a.aliexpress.com/_dX1Dh7u
- Jasongds
6 years 7 months ago #220388
by Jasongds
Replied by Jasongds on topic Ring and pinion
Surely it's your bearings you need to be top quality,Toyo etc,
6 years 7 months ago #220389
by sniper
Replied by sniper on topic Ring and pinion
Raptor do a 4.63
H&M do a 5.12
sniper
H&M do a 5.12
sniper
The following user(s) said Thank You: VITAC
- VITAC
6 years 7 months ago #220393
by VITAC
Replied by VITAC on topic Ring and pinion
Anybody tested these ...or will break apart at the fist slap:)
- Thank you received: 2005
6 years 7 months ago #220402
Replied by Lambert on topic Ring and pinion
As suggested above there are more locally manufactured products available with a much higher quality reputation. Value for money is more important than initial cost to purchase.
6 years 7 months ago #220420
by Busta
Replied by Busta on topic Ring and pinion
A cheaper and less risky option would be fitting the transfer case from an automatic vvt Jimny.
Time to create page: 0.209 seconds
