lost the PAS tensioner nut!!!!
  • DevonChris
25 Mar 2020 14:13 #220251 by DevonChris
lost the PAS tensioner nut!!!! was created by DevonChris
Hello all,
So I was replacing the belt and tensioner bearing on my Jimny PAS (super fidly, lost most of the skin on my hands....), when I dropped the adjustment nut into the engine compartment. Sadly, it didn't hit the ground and I've spent ages looking for it.:dry:
does anyone know what thread the bolt is? The head is 12mm on the bolt (although for some reason it had 11 stamped on it).
thank you in advance!
Chris
25 Mar 2020 16:37 #220254 by mlines
possible M8?
  • DevonChris
25 Mar 2020 17:20 #220258 by DevonChris
Replied by DevonChris on topic lost the PAS tensioner nut!!!!
Thanks, I'm going to need to find a shop open with a range of nuts, but will start with M8 :)
25 Mar 2020 17:43 #220260 by Scimike
I assume like most it will be metric fine?
That's M8 X 1.25 if you are on eBay etc, not the more common M8 X 1.5 (course) thread.
Don't know which, assume fine, but maybe ask for both.
Mike
The following user(s) said Thank You: DevonChris
25 Mar 2020 19:21 #220265 by Busta
99% sure it's M8 coarse. But to be certain, find another 12mm nut in the engine bay and take that as a reference. There is one on the alternator tensioner. The replacement will be 13mm because that is the standard size for an M8 outside Japan. The Japanese, being a superstitious lot, avoid the number 13!
  • X8GGY
29 Mar 2020 11:09 #220409 by X8GGY
Replied by X8GGY on topic lost the PAS tensioner nut!!!!
I've got loads of nuts and bolts in stock and a Post Office on site if you want to avoid going out...
PM me your address and I'll pop some in the post...
Dave
Time to create page: 0.098 seconds
