lifting my jimny
  • Adamski
26 Dec 2010 08:54 #8115 by Adamski
Replied by Adamski on topic Re: lifting my jimny
Another option is to use 2" spring spacers. All you need is shock extender brackets with the standard shocks. All comes in at around £100 I believe. If you do go for the full lift kit I would stay clear of the es3000s as I have these and they make the ride mega harsh. I'm hoping to have a go in someones jimny with es1000s to see if these are any softer.
  • adamjimny
26 Dec 2010 10:36 #8121 by adamjimny
Replied by adamjimny on topic Re: lifting my jimny
if i make it to tong i have es1000's you can have a drive in mine no worrys compare the difference.
  • Adamski
26 Dec 2010 17:55 #8138 by Adamski
adamjimny wrote: if i make it to tong i have es1000's you can have a drive in mine no worrys compare the difference.
That would be great :). How do you find the ride with the ES1000's?
  • adamjimny
26 Dec 2010 21:38 #8151 by adamjimny
well ill be fitting them very soon so ill let you know
27 Dec 2010 23:21 #8214 by ooky_123
Replied by ooky_123 on topic Re: lifting my jimny
Martin, interesting about the Bumper relocation ..
when I lifted mine, I didnt need to modiy the brackets, the bumper mounts are located on the body, and only the lower mounts are located on the chassis.
The only real modification I had to do was with the front chassis tunes, as these puched the bottom of the bumper out. I used the origional mount points, and donot have a gap.
Former owner of Little "Ooky", who has now started a new life in Shetland
  • pjlee25
02 Jan 2011 03:08 #8627 by pjlee25
Replied by pjlee25 on topic Re: lifting my jimny
Adamski wrote: Another option is to use 2" spring spacers. All you need is shock extender brackets with the standard shocks. All comes in at around £100 I believe. If you do go for the full lift kit I would stay clear of the es3000s as I have these and they make the ride mega harsh. I'm hoping to have a go in someones jimny with es1000s to see if these are any softer.
Does that mean the by using a 2" spring spacer, there is no other modification needed? i.e. extension of hose, brake lines, pan-rod, bumper alignment, etc?
I've seen a couple of eBAY listing on 2" spring spacer... just want to confirm that the 4 pieces are all that is required to make my Jimny taller, whilst still maintaining the look.
