oilseals
6 years 8 months ago #219293 by safari
oilseals was created by safari
do someone have all specs or size of front hub and rear hub oil seals pls
if u worry u die if u dont worry u still die so why worry
6 years 8 months ago #219354 by kirkynut
Replied by kirkynut on topic oilseals
Have a look in the BigJimny Store and buy them from there while you are there.
You then know that you are getting the right ones, likely at the cheapest price you can get them, of a great quality and you support the forum financially all in one swoop!
6 years 8 months ago #219375 by Scimike
Replied by Scimike on topic oilseals
It could be a long wait for an answer to this, as Kirkynut said I believe most of us just get the kit from the Big Jimny store and fit it. If you can this is your best option, if you can't it may be a case of removing the seal and measuring yourself to see if you can source one locally.
6 years 8 months ago #219404 by kirkynut
Sorry, perhaps I should have been clearer. The spec is on the Big Jimny Store but I suggest just buying from there though for the reasons I mentioned:
Small oil seal that fits inside the front axle shaft
Generic Part Size: 26 x 38 x 8 TC R23
Suzuki Equivalent Part. No. 09283-26016
The following user(s) said Thank You: safari
6 years 8 months ago #219460 by safari
Replied by safari on topic oilseals
tks to everyone for the help
had to buy them local could not wait
Time to create page: 0.089 seconds
