Who put it there?
6 years 9 months ago #218152 by Fossie
Who put it there? was created by Fossie
The sump plug on 13 g engine , why is it so close to panhard bar at an angle.....and why was it fitted by a gorilla.?
Service day ...managed to do everything except change oil, laying on your back with inches of wiggle room on a ring spanner because the sockets wouldn't fit in the space....
Go one let me in to the system ...tell me I'm a muppet .!
6 years 9 months ago #218155 by Scimike
Replied by Scimike on topic Who put it there?
I feel your pain.
In general for a compact vehicle the majority of items are easy access, however the gearbox fill point got me shouting, almost impossible to put oil back without a EP shower!
That said just changed the pre cat Lambda sensor on my son's MR2, totally unaccessible until I had removed all the exhaust system and part of the rear subframe - snapped every bolt ----two weeks under a very low vehicle - rant over.
So it can be worse!
Can't help with any tips, it must be better on the M13A as I can't recall any problem.
Mike
  • Mudman
6 years 9 months ago #218157 by Mudman
Replied by Mudman on topic Who put it there?
Easiest way I found to do the gear box was get a length of garden hose and feed it as straight as you can from the engine bay then poor the oil down there (easier with two people)
6 years 9 months ago #218159 by kirkynut
Replied by kirkynut on topic Who put it there?
For getting the oils in I use:
www.machinemart.co.uk/p/tool-connection-...i-purpose-mini-pump/
To get to the sump nut, if you jack the car up on the chassis the suspension will drop, giving you more room.
The following user(s) said Thank You: Fossie
  • CC Baxter
6 years 9 months ago #218160 by CC Baxter
Replied by CC Baxter on topic Who put it there?
Gearbox and dif oil filling, I have always used a cheap garden sprayer, B&Q sort of thing. I made a little U shaped filler end from some small bore copper and then jam that in the end of the sprayer pipe. Put slightly more oil in it than the box needs, pump up to pressure and then go for a cup of tea. Return 20 minutes later and job done. To avoid spills I use cat litter trays (again cheap), why waste money?
Chris
6 years 9 months ago - 6 years 9 months ago #218161 by mlines
Replied by mlines on topic Re:Who put it there?
I use a boat oil pump. Cheap and screws into the oil bottle. Warm the oil in the airing cupboard overnight first makes it really easy
www.force4.co.uk/quicksilver-lube-pump.h...aZqJ1ABoC56sQAvD_BwE
Last edit: 6 years 9 months ago by mlines.
Time to create page: 0.101 seconds
