Heater Control Panel - replacement bulb details. 53 plate
04 Feb 2020 21:23 #218055 by PHB1969
Hi
My heater control lighting has given up. Suspect it's the bulb and have seen the guide for replacing.
Before I start I would like a bulb so I can swap it out / in at the same time.
So can anyone give me the details of the bulb I need, even a link to where I can buy one.... What could even be better would be an Led replacement.
Thanks
Paul
04 Feb 2020 22:29 #218061 by Max Headroom
Paul - not sure if this is relevant, but have you seen THIS thread?
05 Feb 2020 18:32 #218081 by PHB1969
Hi Max - blissfully scrolled through that thread and missed the links to the video and bulbs!
One quick question - are those the bulbs I want for the heater?
Cheers
Paul
  • Daniel30
05 Feb 2020 19:13 #218082 by Daniel30
The heat selector on my panel looks dim so I will probably pull it out at the weekend and have a look, I'll report back with my findings ;) but mine is an 2007 plate
05 Feb 2020 23:01 - 05 Feb 2020 23:01 #218090 by Max Headroom
PHB1969 wrote: Are those the bulbs I want for the heater?
Paul - sorry but I can't answer that; I just don't know.
The chances are they could well be the same/similar but you probably won't know that until you have physically accessed the bulbs themselves
Last edit: 05 Feb 2020 23:01 by Max Headroom.
The following user(s) said Thank You: Daniel30
Time to create page: 0.090 seconds
