4wd low and high panel bulbs
11 Feb 2024 17:59 #254233
by DSJ271168
Replied by DSJ271168 on topic 4wd low and high panel bulbs
Sounds difficult!!!! Looked for a guide/video but can’t seem to find one anywhere
- IzakJackson
- Junior Member
21 Feb 2024 17:39 - 21 Feb 2024 17:44 #254501
by IzakJackson
I'm an adventure filmmaker & photographer exploring in my Gen 3 Jimny.
Replied by IzakJackson on topic 4wd low and high panel bulbs
Just replaced my 4wd and hazard bulbs thanks to this thread, much simpler process than I thought it would have been.
I went to swap the heater control bulbs, but it turns out they're different bulbs. Does anyone know what the correct one is? They're significantly dimmer now so want to replace!
Bonus points for anyone who can tell me how to swap the bulb on the heated mirrors/rear window button, I couldn't figure out where the bulb was.
Last edit: 21 Feb 2024 17:44 by IzakJackson.
- IzakJackson
- Junior Member
23 Feb 2024 12:21 #254530
by IzakJackson
Found out they're a Toshiba V-2 lamp. Got some on order.
For the heater button, when you unclip the cables from the back, you can also unclip the insert. You'll then find two lamps in the insert and can add the same ones that were used for the 4wd buttons.
Last lamp I want to figure out is the AC button, but getting the heater controls out fully is a bit of a pain.
- IzakJackson
- Junior Member
06 Mar 2024 10:18 #254854
by IzakJackson
Got my heater controls sorted - crazy how dim the lamps got after 12 years!
Time to create page: 0.594 seconds
