Wheel question :)
12 Jan 2020 22:35 #217220
by Tasker
Wheel question :) was created by Tasker
First off, I swear I have looked. But sadly I have gone cross eyed.
Is anyone running 15x7 ET0 or ET10 Steel wheels on a bone stock Jimny.
Im currently on the 3 spoke alloys on a 2004 and I want shot of them. however I have some concerns that the width increase from 5.5 to 7 may cause some issues and while the site contains lots of info regards tyres sizes I have struggled to find anything definite regards wheel widths.
Many thanks
Tris
Many thanks
Tris
- Thank you received: 2005
13 Jan 2020 05:09 #217222
Replied by Lambert on topic Wheel question :)
As far as I am aware 7s fit fine. Bearing in mind that the relationship between the wheel and axle is fairly consistent regardless of what other modifications have been done to the rest of the suspension. The clearance arc of the actual rim is only really going to be affected if the king pin axis is altered and that would require different axles. The suspension modifications are all about the size of tyre not the size of the rim. Hope that makes sense.
Time to create page: 0.211 seconds
