Really need help now...
  • Basketcase
6 years 10 months ago #216953 by Basketcase
Really need help now... was created by Basketcase
Right I posted a while ago about my jimny being poorly...aka f****d... the timing belt was pretty slack so I swapped that..I thought the timing was out but I don’t really know..watched 3 videos on YouTube and they’re all different..time with cyl 1, cyl 4 blah blah I assume it’s timed up ok but have no idea how to check the bottom crank lines up with the mark on the case, the cam pulley lines up the I&E mark on the pulley but there’s a single I and a single E mark also..should it line up with one of those instead? I’ve had the exhaust off to check that’s not blocked(just took it off at the manifold as it was easier) starts but still won’t rev...all the intake sensors have been changed and makes no difference...any ideas further?
Cheers guys
  • Basketcase
6 years 10 months ago #216955 by Basketcase
Replied by Basketcase on topic Really need help now...
I will sell it if anyone wants it for something? It’s got 235/75 15 mud tyres on it, 2-3” suspension lift and a 2” body lift.mot till next year...or if anyone needs parts.
6 years 10 months ago #216957 by Lambert
Replied by Lambert on topic Really need help now...
If it won't rev with the manifold off I would suggest it is not quite timed perfectly. Unfortunately I don't know what the actual correct procedure is to time a g series but I am certain someone will on here, guys?
The following user(s) said Thank You: Basketcase
6 years 10 months ago #216960 by maverick
Replied by maverick on topic Really need help now...
Time to take it to your friendly garage
Jalapeño, IISY?
6 years 10 months ago #216975 by kirkynut
Replied by kirkynut on topic Really need help now...
Does it pop and bang with misfires as that is usual when the timing is more than a little out.
If the cam and crank markings are in line on the right stroke then I'm at a loss too.
Does it idle fine?
  • Basketcase
6 years 10 months ago #216981 by Basketcase
I’m not sure if the crank and cams are in the right time or anything. It isles fine just as soon as you press accelerator it bogs right down and cuts out..you can get it to rev if you let off and quickly press and let off the pedal repeatedly
