Re:Pulse counting
6 years 10 months ago - 6 years 10 months ago #216575
Pulse counting was created by mlines
So with the tyres 235/85R16 and 3.9 diffs, the speedo will need correction.
My old pulse is set up for 235/75/R15 on the 3.9 diffs.
So some maths help needed. What teeth count will I need on the pulse generator to get the correct speedo reading?
Thanks
Thanks
Last edit: 6 years 10 months ago by mlines.
- Thank you received: 2005
6 years 10 months ago #216576
Replied by Lambert on topic Pulse counting
Allegedly the 16 inch is 6.6% larger circumference or 44 revs per mile less. What is your current pluses with the 15s?
6 years 10 months ago #216577
Replied by mlines on topic Pulse counting
My own googling seems to show that a standard Jimny has a 25 tooth ring?
So 25 pulses per RPM.
Standard tyres are 205/70R15
According to tiresize.com/calculator/ this will rotate 767 times per mile
With 3.909 diffs, the propshaft will rotate 2,998 times, so would generate 74955.075 pulses.
So my 235/85R16 will rotate 636 times which equates to 2486.124 propshaft rotations
With rounding up its 75000/2486 = 30 approx.
I think I need a 30 tooth ring???
6 years 10 months ago #216578
Sorry, cross posted with Lambert
6 years 10 months ago #216579
The above sounds about right. Alternatively the obd2 screen thing I have can be calibrated and gives you a digital readout?
6 years 10 months ago #216580
Replied by mlines on topic Re:Pulse counting
Lambert, yes my obd2 reader does have a correction setting, but thought I would get the Speedo correct as well whilst building the new one
Time to create page: 0.091 seconds
