M13AA engine hesitation
- mickt
6 years 11 months ago #216451
by mickt
M13AA engine hesitation was created by mickt
Daughter reports that when she gets to 40mph in top gear the car shudders/hesitates so is engine related. If she goes through that speed it returns to normal. The car is well serviced so could it be indicative of a camshaft sensor failing intermittingly? I have not drove it to check but will do and see what is actually happening.
- Thank you received: 2005
6 years 11 months ago #216452
Replied by Lambert on topic M13AA engine hesitation
Also check the spark plugs are correctly torqued. But it is more likely a sensor.
- mickt
6 years 11 months ago #216479
by mickt
Replied by mickt on topic M13AA engine hesitation
I torqued the plugs to the correct value when I refitted the engine after the clutch change but will be taking them out for a look see today to check them. Thanks for reply.
- mickt
6 years 10 months ago #216902
by mickt
It continues to happen when cold after standing all day/night. Once through the 40mph speed it clears and does not return that journey.
- mickt
6 years 10 months ago #216992
by mickt
Hoicked the plugs out. Colour of burn is same on all four. Regapped them and refitted. Still does it but it is when she is in 4th and accelerates to try to get to 50 to go into 5th gear. The engine temp gauge is in the middle so engine has reached the "normal" temp. Again she gets through it and the car is as good as gold for the rest of the day. It stands for 10 hours at work and is no bother on the way home. Anybody got any thoughts?
Time to create page: 0.086 seconds
