no 4x4 green light
- ozzyboy
6 years 11 months ago #216164
by ozzyboy
no 4x4 green light was created by ozzyboy
the 4x4 green light does not come on at all
I didn't want to try the 4x4 system on tarmac
does this fault mean its not working
- Thank you received: 2004
6 years 11 months ago #216170
Replied by Lambert on topic no 4x4 green light
Yes. It's more likely to be an electric issue than a vacuum lines one. Starter for ten is to look under the car and check the condition of the wires and plugs on the transfer box. If everything seems visually ok plug and re plug the connectors to clean the contact pins. After that it starts to get a bit more involved so easy and free stuff first.
The following user(s) said Thank You: ozzyboy
Time to create page: 0.075 seconds
