Front propshaft problem
6 years 11 months ago #215760
by giacomom
Front propshaft problem was created by giacomom
Goodmorning everyone
after to fit a 70 mm lift kit ,I have the problem of contacting the front drive shaft against the cross member of the chassis side members
on the drive shaft I have already mounted a 15 mm alloy spacer shaft
how can i solve ?
thank you
Giacomo
how can i solve ?
thank you
Giacomo
- Thank you received: 2005
6 years 11 months ago #215761
Replied by Lambert on topic Front propshaft problem
What year is the Jimny? The newer ones need a different cross member the older ones should be ok at that height.
6 years 11 months ago #215762
by giacomom
Replied by giacomom on topic Front propshaft problem
Thank you Lambert
1998
1998
6 years 11 months ago #215763
Which end of the drive shaft did you put the spacer on, transfer box or differential end?
6 years 11 months ago #215766
by giacomom
Differential end
Giacomo
Giacomo
6 years 11 months ago #215771
Ok. I think people usually put the spacer on the transfer box end. Thing is I'm not sure how or what your drive shaft is touching? Even with no springs and the suspension on full compression mine doesn't catch and also with the dampers off and the axles lowered to the extent of the anti roll bar I still don't have interference on my front drive shaft.
Time to create page: 0.094 seconds
