Re:HELP! Clutch release arm spring
7 years 6 days ago - 7 years 6 days ago #215566
by gv42
HELP! Clutch release arm spring was created by gv42
Help! brother is replacing the clutch on his Jimny, when the spring that holds the clutch release arm broke, doesn't hold the arm now, anyone got one spare?!!
i think the part number is 23241-78A20-000
its a 2003 plate
its a 2003 plate
Last edit: 7 years 6 days ago by gv42.
7 years 6 days ago #215578
Replied by mlines on topic Re:HELP! Clutch release arm spring
£4.21 plus £2.20 postage
7 years 4 days ago #215618
by gv42
Replied by gv42 on topic Re:HELP! Clutch release arm spring
Many thanks for the quick reply Martin!
The Suzuki Clutch kit comes with the Spigot/pilot bearing, and my brothers one was a bit notchy and loose, well worth checking and replacing when you do your clutch! as for the Fork release clip/spring, worth bearing in mind, might be something else that may need to be changed, when doing a clutch?
again, many thanks!
Mark
again, many thanks!
Mark
Time to create page: 0.082 seconds
