Fan belt AGAIN!
09 Nov 2019 10:23 - 09 Nov 2019 10:24 #215505
by Fossie
Fan belt AGAIN! was created by Fossie
Asking on behalf of my daughter, who some may have met on the Jimny meet. ( red hard top jobbie)
Anyway her fanbelt snapped again 3rd or 4 th in a year. The crank pulley has been checked by the local garage , when they fitted a new water pump. But can you diagnose the fault of bonding failure when cold and stationary in fairness.?
This morning ...the first deep frost , it squealed a bit but soon stopped , went to the stables and the usual smell , signs ...yep no coolant and a snapped belt.
Question which is the more likely cause , alternator bearings or crankshaft pulley. In ideal world both , the water pump is new so shouldn't be that,
It's a 2004 hard top so M13 engine no aircon .
She phoned hoping to just borrow our cabrio ....but as fate would decree our brake pipe are gash as per another thread.....
Ps I have read some other threads on here but no conclusions it seems .
Last edit: 09 Nov 2019 10:24 by Fossie.
09 Nov 2019 10:57 #215506
Replied by mlines on topic Re:Fan belt AGAIN!
With the engine running, look at the pulley/belt. Is there any wobble
- Jimny Sprocket
13 Nov 2019 14:00 #215604
by Jimny Sprocket
Replied by Jimny Sprocket on topic Re:Fan belt AGAIN!
I’ve had two snap on me, after fitting the second replacement I checked and adjusted tension.
I get squealing sometimes when I first start, I avoid using the blower and heated rear window and any lights and let the car idle for a couple of minutes to replenish the battery before driving off.
I know this is more about treating symptoms than a cure, but I can’t find any faults.
- Jimx5
13 Nov 2019 22:32 #215610
by Jimx5
Replied by Jimx5 on topic Fan belt AGAIN!
Only a thought,but have you checked the 'V' on the water pump pulley which you say has recently been changed.
If any of the 'V's' are different, alternator-water pump etc are the wrong profile it will cause excessive wear on the belt under tension.
14 Nov 2019 16:32 #215627
by paul2u
Replied by paul2u on topic Fan belt AGAIN!
i had this kind of thing happen to me a few year ago i was stumped all pullies was ok and the water pump was fine , the problem turned out to be the altornator bearing but the bit was when you spun the pulley it spun well what was happening was after a while running it would tighten up to almost siezin up , i changed the altornator and all was well i went thru a few belts before i got it , best way is to be ready to spin the altornator pully after a trip when everyhting is hot
- mickt
14 Nov 2019 16:48 #215628
by mickt
Replied by mickt on topic Fan belt AGAIN!
Which engine is it? If its the m13 it is not always obvious when inspecting the crankshaft pulley that it is delaminating. My daughters car ran two belts and I replaced the pulley and no further problems. There looked to be nothing wrong with the pulley! Ensure you put the correct length belts on. The numbers relate to the length.
