Fan belt Crank pulley problems
07 Nov 2019 17:46 - 07 Nov 2019 17:47 #215449
by bryn
Fan belt Crank pulley problems was created by bryn
The saga continues.
I changed both fan belts as one of them was squealing and now it appears I have a problem with the crank pulley. It seems to have a wobble and when I let the engine warm up and rev it I get a rattle which seems to be coming from the pulley area. The tensioner seems fine and running true.
I was wondering if I over mentioned the belts and that would have an effect
As always advice much appreciated
bryn
bryn
Last edit: 07 Nov 2019 17:47 by bryn.
07 Nov 2019 17:59 #215451
Replied by Riccy on topic Fan belt Crank pulley problems
The pulley failing is usually what causes people to start changing belts in the first place.
They have a rubber compound as part of their construction which wears out and you get the problem you have found. Possibly tightening the belts properly has brought it on sooner, but its an inevitable thing on a Jimny im afraid.
Martin sells them in the bigjimny shop
07 Nov 2019 20:38 #215459
by Foxtrot
Replied by Foxtrot on topic Fan belt Crank pulley problems
I remember one of my Jimnys got recalled for a faulty defect on one of the pulleys, I think they changed it out for a stronger version as the previous one was prone to failure.
www.check-vehicle-recalls.service.gov.uk...NY/year/2010/recalls
Time to create page: 0.160 seconds
