rear diff
6 years 11 months ago #216458
by Scimike
This is a tough call to suggest possible causes. Is it the same noise as before but now only at 35+mph or are you just hearing a new noise after the other sources have been eliminated?
It could be resonance of a part such as exhaust, heat shield etc, but I would expect it to happen with engine rpm rather than speed. It's possible it's the brake shield but I would have expected it to manifest itself on the mechanics ramp.
Best Idea is to get a passenger to have a listen around as you drive to try and pinpoint the area from which it originates, front / rear is a good start if possible. Then is it only happening when moving and is it engine rpm related.
Good luck
Mike
Good luck
Mike
- jfkenpoman
6 years 11 months ago #216468
by jfkenpoman
Replied by jfkenpoman on topic rear diff
Thanks mate, yes it is the same noise, i thought it may be the brake shield I'll have a check when I finish my 4 night shift pattern
Time to create page: 0.103 seconds
