gearbox swap
7 years 1 month ago #214780 by safari
gearbox swap was created by safari
hi i have a manual gearbox and would like to change to automatic would it be a direct bolt on swap ? i have all harness attached and gearbox is same year of my jimny
if u worry u die if u dont worry u still die so why worry
7 years 1 month ago #214782 by Lambert
Replied by Lambert on topic gearbox swap
You're running a bigger engine aren't you? In a hot and dusty environment. I would think long and hard about doing this as the auto is only just upto a standard Jimny in a temperate environment. If you're determined then add as much cooling as you can to the box, but really I would stop with the manual.
7 years 1 month ago #214785 by safari
Replied by safari on topic gearbox swap
hi tks for your reply
i have standard 13 engine bigger 33tyres and maruti tcase i am thinking of changing cause of the clutch so it gets less worn and stress
7 years 1 month ago - 7 years 1 month ago #214786 by Lambert
Same thing there then. Even with the alteration to the transfer box it's still asking an awful lot of an automatic box and it will generate a noticeable amount more heat which will need dissipating. Also the auto ratios are going to need compensating for with either the transfer box or differentials. Basically it's a lot of work. If the car were unmodified it would be simpler to sell it to buy a factory auto. With modifications that stands but more so. In the end it's your car and your choice but I would look at a manual and a decent clutch.
Last edit: 7 years 1 month ago by Lambert. Reason: Proofing
7 years 4 weeks ago #214945 by safari
what decent clutch would you advise?
7 years 4 weeks ago #214959 by Lambert
When I need a new clutch it will be an exedy probably the heavy duty safari one. They weight up the pedal nicely apparently and are able to handle a decent hike in power or some incorrect gearing to a point.
Time to create page: 0.085 seconds
