Brake caliper rust and paint
7 years 1 month ago #214564
by Bosanek
Brake caliper rust and paint was created by Bosanek
The brake calipers on my 7-year old Jimny 3 are completely and severely rusted.
Is that normal for 7 year old factory fitted brake calipers?
Which paint would be recommended as a durable solution after cleaning the rust off?
- Thank you received: 2004
7 years 1 month ago #214572
Replied by Lambert on topic Brake caliper rust and paint
Yes perfectly normal. Though I did replace mine at 8 years old as the rust had migrated into the slides for the bolts and I was stripping them and cleaning them almost every month towards the end. As for paint any Very High Temperature paint will work but honestly I don't see much point. Painted calipers are only ever vaguely suited to Porsche cars with carbon ceramic brakes and then not really.
- Max Headroom
- Banned
- Thank you received: 216
7 years 1 month ago #214573
by Max Headroom
Replied by Max Headroom on topic Brake caliper rust and paint
Used
THIS
stuff on my SAAB calipers and it stayed on superbly.
If you go down this route, I would suggest cleaning and degreasing, and de-rusting as much as possible before using the can of pre-cleaner provided.
7 years 1 month ago - 7 years 1 month ago #214578
by Scimike
Replied by Scimike on topic Brake caliper rust and paint
+1 for the above product ^^^^^^^^
Sure I obtained from a local Eurocarparts when one of their never ending sales was favourable for paint products. It's on my Jimny and it's lasting quite well. Cutting the rust back (but not removing totally) takes the time, application and drying times are quick. Used about a 1/4 of a can on the two calipers. You can't really see the results on a Jimny which is fine so long as your aim is to hold back the rust and make working on the brakes a little cleaner next time.
Last edit: 7 years 1 month ago by Scimike.
- Jimx5
7 years 1 month ago #214583
by Jimx5
Replied by Jimx5 on topic Brake caliper rust and paint
Hammerite silver smooth is just as good.
7 years 1 month ago #214680
by Paul4A
1999 T registered Jimny. Early G13BB SOHC engine.
Replied by Paul4A on topic Brake caliper rust and paint
Or get them professionally rebuilt at say
www.biggreddemo.auto-guru.uk/
then you know they’ll work and last for years
Paul
Paul
Time to create page: 0.089 seconds
