Jimny's common problems
05 Oct 2019 10:40 #214353 by facade
Replied by facade on topic Jimny's common problems
If it drives fine, just keep it clean underneath- make sure that no mud/road dirt or salt build up anywhere and it will be fine with regular servicing.
The following user(s) said Thank You: TautvydasP
06 Oct 2019 07:38 #214374 by kirkynut
Replied by kirkynut on topic Jimny's common problems
There was a W reg 1999 single cam Jimny in our family that was once mine until it failed the MOT on terminal rust earlier this year. That never needed a king pin bearing or anything other than engine oil change and brake pads with the odd cam belt in 120k miles.
So it's not a given that you will have any issues.
Having said that, her replacement has already had me fit kingpin bearings to one side and that's started leaking again at the hub, so I've got to investigate more!
Time to create page: 0.067 seconds
