Lilly belts
  • Rob
7 years 1 month ago #214034 by Rob
Lilly belts was created by Rob
Hi guys n gals. For the forth time in as many years my alternator belt has broken. Always in heavy rain. Any suggestions?
7 years 1 month ago #214037 by Lambert
Replied by Lambert on topic Lilly belts
I would be looking at the crank drive pulley. They are a rubber bonded type and are prone to failure in the rubber causing the belts to die prematurely. If with the belts off you can move the pulley in or out it is goosed. Also while the belts are off check the rest of the rotating components are able to spin freely as it could be a bad bearing.
  • mickt
7 years 1 month ago #214055 by mickt
Replied by mickt on topic Lilly belts
Happened on my daughters car and it was the pulley. Looked and felt OK but cured the fault. Make sure you get the correct size belt length wise.
Time to create page: 0.075 seconds
