Rear door central locking
  • GF68
7 years 1 month ago #213937 by GF68
Rear door central locking was created by GF68
On my 2005 when I unlock the drivers door the rear door unlocks with the central locking, but when I close the car, I have to manually open rear, press down button while holding lever and shut door.
Any ideas where to start to look for the issue?
7 years 1 month ago #213944 by Lambert
Replied by Lambert on topic Rear door central locking
Sounds like the solenoid in the locking mechanism is sticking or has an electrical problem. Take the panel off the back door and inspect the actuator. Or it could be a bent or misplaced lever and that will be obvious.
The following user(s) said Thank You: GF68
  • GF68
7 years 1 month ago #213975 by GF68
Replied by GF68 on topic Rear door central locking
Thanks Lambert, stripped it down it was a lever that had come off, so thankfully an easy fix.
7 years 1 month ago #213979 by Lambert
You are welcome. Glad you had an easy fix.
Time to create page: 0.113 seconds
