Re:LAMBDA Sensors for the M13A engine
- Max Headroom
Topic Author
- Banned
- Thank you received: 216
7 years 1 month ago - 7 years 1 month ago #213851
by Max Headroom
LAMBDA Sensors for the M13A engine was created by Max Headroom
Hello all.
I'm about to change the CAT on my VVT M13A engined convertible.
I've had issues with the engine managment light staying on and changed the upper/forward Lambda sensor a few months back.
The car struggled through the emissions section of the MOT so its probably time to cx the CAT, and while doing so I'm going to replace the lower/aft LAMBDA sensor.
I believe these were originally Denso, but I'm struggling to find a part number.
Could someone please help identifying the (Denso) part numbers, particularly for the lower/aft sensor for the M13A?
Last edit: 7 years 1 month ago by Max Headroom.
7 years 1 month ago #213855
by Scimike
Replied by Scimike on topic LAMBDA Sensors for the M13A engine
The following user(s) said Thank You: Max Headroom
- Max Headroom
Topic Author
- Banned
7 years 1 month ago - 7 years 1 month ago #213858
by Max Headroom
Replied by Max Headroom on topic LAMBDA Sensors for the M13A engine
Thank you Scimike, it sort of helps...
I think it's the bottom one in that list, but the part number "LP-21149" isn't actually a Denso part number, so I can't cross-refer it to anything.
They're about £20 more than anyone else by the looks of it too :ohmy:
...which is another good reason to x-refer a genuine Denso number
7 years 1 month ago #213865
by kirkynut
Replied by kirkynut on topic LAMBDA Sensors for the M13A engine
Perhaps give Martin your registration number and VIN and ask him nicely to get you one via the BigJimny Store?
You know that you'll get the right part and likely genuine that way.
7 years 1 month ago #213870
Replied by mlines on topic LAMBDA Sensors for the M13A engine
YOurs lists as 18213-76J10
The equivalent part is
www.amazon.co.uk/Blue-Print-ADK87010-lam...sensor/dp/B00B8YKMQ4
- Max Headroom
Topic Author
- Banned
7 years 1 month ago - 7 years 1 month ago #213873
by Max Headroom
Thank you Martin, I'll take a look. I assume you cant supply one?
...damn thse things are pricey
EDIT: Using your part number (a huge help thank you) I have found a Denso one from Spark Plugs UK s for £65 inc next day postage
Time to create page: 0.099 seconds
