Steering pull
- BAN1
7 years 2 months ago #213561
by BAN1
Steering pull was created by BAN1
Hi - I have had my Mk4 since March 2019. I love it! It has one issue that I dont like though... it pulls to the right all the time. Looking underneath it seems the steering damper 'pushes on the steering knuckle to the right. Would this be the cause and will it get better as time passes. The dealer just says "even our demonstrator does it a bit" and left it at that. I tired getting a local garage to realign the steering against the Mk3 toe in spec. Just get tyre squeal at tight turns after this. Pull is unchanged. Does seem to be getting less as miles increase (done 3000 now). Has anyone else noticed this steering pull on Mk4s?
- CC Baxter
7 years 2 months ago #213562
by CC Baxter
Replied by CC Baxter on topic Steering pull
Sorry to hear that Ban1. I can't say I've noticed any issues with pull and have done a few more miles than that. I must say I've been driving mainly 4x4s for 30+ years and my expectations are probably lower than they should be. Why not try another dealer (on the grounds of safety) or a tyre shop with good wheel alignment facilities.
Chris
Chris
7 years 2 months ago #213569
Replied by Soeley on topic Steering pull
I have not noticed any pull in the steering, mind you I haven't driven with 'no hands'. Tyre squeal is pretty normal though. I would try another dealer.
- Max Headroom
- Banned
- Thank you received: 216
7 years 2 months ago #213570
by Max Headroom
Replied by Max Headroom on topic Steering pull
The usual suspects are:
Uneven tyre wear between the front tyres eg one worn out, the other new
Uneven tyre pressures
Tracking incorrectly set up
Sticking brake caliper
Damaged suspension component
Tyre damage
I understand your frustrations; with a realatively new vehicle none of the above should be applicable.
Check you have the correct tyre pressures - damned workshops overinflate my tyres every time it goes in.
Tyre damage
- BAN1
7 years 2 months ago #213595
by BAN1
Replied by BAN1 on topic Steering pull
Thanks for all the comments. I wondered if it was to do with the electric steering assist not being set to centre. As the pull to right is getting weaker as the miles go on I'm going to ignore it.
- Max Headroom
- Banned
7 years 2 months ago #213629
by Max Headroom
Try going from lock to lock a good few times - particularly if you can jack the front up - excercising the system might clear something [he said, clutching at straws
Time to create page: 0.098 seconds
