LEAKING 1.6 INJECTOR BLOWING BACK (FOUND PART)
  • invincible
13 Sep 2019 14:31 #213476 by invincible
done the engine swap , and one of the 1.6 injectors is blowing fuel out of itself, from top. are there anyways of clearing it, id get a new one but thats 3 days from germany, darlo suzuki. anyone had this fault before, will the 1.6 engine run on the 1.3 injectors, worst case scenario until i can get a replacement or will it do in the ecu? need to get fixed this weekend or its another week off work, any help ideas would be v much appreciated, cheers in adavnce
13 Sep 2019 15:13 #213479 by Keithy
What colour are your injectors.
I have orange and purple here in Leeds.
Have you checked the top "O" ring is in place?
It'll run fine on the 1.3 injectors.....should manage to drink enough fuel lol
13 Sep 2019 15:19 #213480 by Riccy
I had this same issue trying to fit the injectors. As Keith says, check the rubber o rings. Its tricky to get them all seated in correctly and stop the fuel leak.
Worst case it will be happy enough with the 1.3 injectors (thats whats in my M18 currently and its fine)
  • invincible
13 Sep 2019 18:22 #213486 by invincible
Replied by invincible on topic LEAKING 1.6 INJECTOR BLOWING BACK NEED ONE DESP,
hey keithy, blues ones mate, just one was leaking at the top, moved its place and it still leaked, i found 4 for £80 delivered of tebay. thanks for offer mate,
so the 1.3 ones would of been ok? arrrrgghhh doh!! another £80 down!! ha ha!
cheers L
  • invincible
13 Sep 2019 18:25 #213487 by invincible
hey riccy, thanks for rapid reply, bugger so the 1.3s would have been ok then,
i thought happen they would spit less fuel in ? did your 1.8 injectors knacker up?
L
14 Sep 2019 06:54 #213503 by Riccy
invincible wrote: hey riccy, thanks for rapid reply, bugger so the 1.3s would have been ok then,
L
The 1.8 ones I tried were putting too much fuel in. You could hear it evaporating in the exhaust after trying to run it and it was running badly (rough). Tried all sorts but ended up going to the 1.3 injectors and all was well. My 1.3 injectors are orange, the 1.8 were yellow and I think the 1.6 were blue, but I dont know if the colours mean anything or not.
Ive been looking into throttle body setups and better exhaust so I will keep them incase they are useful for that (if it ever happens)
