Body Mount Replacement
  • Bazh1
7 years 2 months ago #213196 by Bazh1
Body Mount Replacement was created by Bazh1
Morning all, I need to repair my body mounts, the ones below the door hinges, what is the best way to do this, it looks like taking the interior out, and cutting the floor, rebuilding and welding it back in from the top.
Has Somebody done this, if so what is the best way.
Thanks In Advance, Barry.
7 years 2 months ago #213207 by Lambert
Replied by Lambert on topic Body Mount Replacement
On the body or the chassis?
  • Bazh1
7 years 2 months ago #213224 by Bazh1
Replied by Bazh1 on topic Body Mount Replacement
The body mounts. The chassis ones are ok atm.
7 years 2 months ago #213225 by Riccy
Replied by Riccy on topic Body Mount Replacement
Its in more than one part. The actual floor panel is a pretty simple thing and easy to patch or cut-out and replace for access. Trim/wiring, etc will all need to be out to cut and weld around it. Be aware that the body is supported by this so needs to be strong.
There is a bracket spot welded and glued to the floor panel. That is the part you will need to find/buy/make by the sounds of it. Has a long bolt as part of it which is what bolts the body to the frame (through the rubber bushes).
I dont know if its a part available, but a message to Martin through the bigjimny.com shop should yield results :-)
  • gfinlayson
7 years 1 month ago #214366 by gfinlayson
Replied by gfinlayson on topic Body Mount Replacement
I need to replace these on mine too, any idea if the part is available to buy or is it a make your own?? Cheers
Time to create page: 0.095 seconds
