4x4 issue
- Markus171295
7 years 2 months ago #213054
by Markus171295
4x4 issue was created by Markus171295
Fitted manual hubs, how do I go about disconnecting and capping the vacuum lines to turn off the flashing light.. also will this allow low gear ratio to be selected??
- Thank you received: 2005
7 years 2 months ago #213059
Yes you can have low range now in either 4x2 or 4x4 depending on if you have locked the hubs or not. I capped my vacuum lines up by the solenoid valves under the battery and left the rest in place to keep the muck out.
Time to create page: 0.073 seconds
