Ecu fault
- noton90
7 years 2 months ago #212790
by noton90
Ecu fault was created by noton90
Hi. Sorry I'm new here and tried to search for info but not found anything. I've got a 2001 suzuki jimny twin cam with a faulty ecu. Now my plan is to get another ecu with immobiliser unit locks and key ect. Now does anybody know if all the numbers on my old ecu have to match all the numbers on the new ecu or as I'm replacing everything does it not matter.
- Thank you received: 2005
7 years 2 months ago #212808
Welcome to the forum. I assume that you have had the ecu on a diagnostic device and are confident that the fault is internal to the actual ecu? If so then a full swap of matching ecu immobiliser and keys from as similar age vehicle as possible is probably the simplest route.
- noton90
7 years 2 months ago #212815
by noton90
Replied by noton90 on topic Ecu fault
Time to create page: 0.080 seconds
