Battery terminals
- wejxf03
13 Aug 2019 15:56 #212066
by wejxf03
Battery terminals was created by wejxf03
Apologies if this seems a silly question but am new to Jimny ownership (2001 Jimny auto).
I cannot seem to tighten my battery terminals up enough to make a good reliable connection.
The terminal have sleeves (adapters?) round them.
When I measure the terminals without the adapters they seem to be 10mm -ve and 12mm positive.
Do I buy new sleeves/adapters or change the terminals?
Thanks in advance
John
Thanks in advance
John
- Thank you received: 2004
13 Aug 2019 17:40 #212070
Replied by Lambert on topic Battery terminals
On our old 2004 Jimny I made a couple of shims out of some copper pipe cut to a suitable length and then split to allow movement. Worked flawless.
The following user(s) said Thank You: wejxf03
- wejxf03
14 Aug 2019 10:37 #212084
by wejxf03
Replied by wejxf03 on topic Battery terminals
Thanks for reply Lambert.
Think I will go for belt n braces and change both the adapters and terminal clamps.
They both look past their best!
Incidentally if I find that the battery has had it I presume I can find a new battery the same size and terminal layout and do away with the adapters?
- Podge
14 Aug 2019 10:52 #212085
by Podge
Replied by Podge on topic Battery terminals
To be honest and because I'm cheap, I'd just use some degreaser and some sand paper to tidy up those connections. Fit a larger shim like Lambert suggested.
14 Aug 2019 11:09 #212086
As above just touch the terminals with a wire brush and add a couple of shims. Save the money for something that needs it.
14 Aug 2019 18:16 #212095
by facade
Replied by facade on topic Battery terminals
The Japanese built Jimnys should have the small JIS terminals, rather than the larger SAE sizes. The adaptor is supposed to convert from the small to the large to fit a JIS battery to a SAE car.
Either you have the "wrong" battery- is your Jimny a soft-top? or the "wrong" terminals.
However, as Lambert says, just add a strip of copper between the terminal and the adaptor.
