Battery terminals
  • wejxf03
7 years 3 months ago #212066 by wejxf03
Battery terminals was created by wejxf03
Apologies if this seems a silly question but am new to Jimny ownership (2001 Jimny auto).
I cannot seem to tighten my battery terminals up enough to make a good reliable connection.
The terminal have sleeves (adapters?) round them.
When I measure the terminals without the adapters they seem to be 10mm -ve and 12mm positive.
Do I buy new sleeves/adapters or change the terminals?
Thanks in advance
John
7 years 3 months ago #212070 by Lambert
Replied by Lambert on topic Battery terminals
On our old 2004 Jimny I made a couple of shims out of some copper pipe cut to a suitable length and then split to allow movement. Worked flawless.
The following user(s) said Thank You: wejxf03
  • wejxf03
7 years 3 months ago #212084 by wejxf03
Replied by wejxf03 on topic Battery terminals
Thanks for reply Lambert.
Think I will go for belt n braces and change both the adapters and terminal clamps.
They both look past their best!
Incidentally if I find that the battery has had it I presume I can find a new battery the same size and terminal layout and do away with the adapters?
  • Podge
7 years 3 months ago #212085 by Podge
Replied by Podge on topic Battery terminals
To be honest and because I'm cheap, I'd just use some degreaser and some sand paper to tidy up those connections. Fit a larger shim like Lambert suggested.
7 years 3 months ago #212086 by Lambert
As above just touch the terminals with a wire brush and add a couple of shims. Save the money for something that needs it.
7 years 3 months ago #212095 by facade
Replied by facade on topic Battery terminals
The Japanese built Jimnys should have the small JIS terminals, rather than the larger SAE sizes. The adaptor is supposed to convert from the small to the large to fit a JIS battery to a SAE car.
Either you have the "wrong" battery- is your Jimny a soft-top? or the "wrong" terminals.
However, as Lambert says, just add a strip of copper between the terminal and the adaptor.
Time to create page: 0.098 seconds
