Jimny 1999 Scan Tool
- Owl
7 years 3 months ago #211842
by Owl
Jimny 1999 Scan Tool was created by Owl
Hi All, Is there a scan tool on the market that will work with the Jimny 1999, G13BB engine? It has an OBDII port but its age would suggest its OBD1 protocol. Any information much appreciated.
How much would a dealer charge to hook up their scan tool for diagnostics? look forward to your reply. Owl.
7 years 3 months ago #211899
by kirkynut
Replied by kirkynut on topic Jimny 1999 Scan Tool
Have a search on this forum as someone found one once.
- Reason2doubt
7 years 3 months ago #211903
by Reason2doubt
Replied by Reason2doubt on topic Jimny 1999 Scan Tool
Interested in this as well Owl! Been curious about my supposed OBDII port (probably OBD1 as you say).
Cheers -
Cheers -
- Owl
7 years 3 months ago #212011
by Owl
Replied by Owl on topic Jimny 1999 Scan Tool
No eBay APP ID and/or Cert ID defined in Kunena configurationIs this the correct scan tool to buy for early OBD1 , Jimny G13BB engines. Look forward to your advice, Owl
- MadsV
7 years 3 months ago #212034
by MadsV
Replied by MadsV on topic Jimny 1999 Scan Tool
You wont get any data on a scanner, its too old. Just use a paper clip and short two pins, google which one, and the check engine light will blink the code
- Owl
7 years 3 months ago #212051
by Owl
This vehicle has an OBDII port under the dash, is there another set of terminals that I use to jumper pins for codes?
Got a check engine light that comes on when highway driving, otherwise stays off when 4WDing, or short runs around town. i did have an alternator bearing squeal that showed up, Ive just replaced the alternator today.
Could that have been the pre-cursor to the check engine light coming on.? i also noticed the 3 alternator pins and socket had a white powder corrosion look about it, may have been bad connections going on.
