Front differential bolts
  • drzjohn
7 years 4 months ago #211084 by drzjohn
Front differential bolts was created by drzjohn
How can I find out how many bolt hold the ring gear on in a front diff. Some are 8 and some are 10 bolt. (Dont say take the diff out)
7 years 4 months ago #211092 by sniper
Replied by sniper on topic Front differential bolts
I think you can tell by the spline count on the drive shafts... I have a vague memory of reading about it in the wiki pages, hope it helps....
sniper
7 years 4 months ago #211097 by Riccy
Replied by Riccy on topic Front differential bolts
No they all use 22 spline shafts into the diff, can be upgraded to 26 with new side gears.
If you cant take it out then it is possible to see in through the oil filler hole and count the bolts that way.
Rears are all the same through the years (10 bolt), Fronts differ and I cant remember which one is which year. I think its 10 bolt for the 3.9 diffs, but could be wrong.
Is this for a locker of some sort?
  • drzjohn
7 years 4 months ago #211104 by drzjohn
Replied by drzjohn on topic Front differential bolts
Yes its for an air locker. I've tried to look through the filler hole and can't see the bolts. I have spoke to Suzuki parts and they say it should be an 8 bolt
7 years 4 months ago #211109 by zukebob
Replied by zukebob on topic Front differential bolts
My understanding is that 1998 - 2003 were 8 bolt. After that they were 10 bolt. My understanding is also that the change was during the 2003 model production. If your Jimny is a 2003, you may need to talk to a dealer/supplier that can use your VIN to determine the count.
Time to create page: 0.150 seconds
