changing spark plugs s3 vvt 2017
- barnsley john
14 Jul 2019 18:20 - 14 Jul 2019 18:21 #211055
by barnsley john
changing spark plugs s3 vvt 2017 was created by barnsley john
i all just got a problem explained in a post earlier flat spot on tick over
so i am going to change the plugs anyway
first problem i have seen is when removing the spark plug plastic cover is there are only two spark plugs showing with two coil packs where the other two plugs are
am I right you need to take the coil packs off to get to the plugs ?
and before I take them off what are the best spark plugs to buy before I take them out has I want new ones here before attempting the job
thanks john
thanks john
Last edit: 14 Jul 2019 18:21 by barnsley john.
14 Jul 2019 19:40 - 14 Jul 2019 19:42 #211062
by Scimike
Replied by Scimike on topic changing spark plugs s3 vvt 2017
Hi John,
Yes you are correct. Each coil pack sits on top of one plug with an extension lead to a second plug. It's a wasted spark system as both plugs that share a coil pack fire at the same time.
You can fit two types of plugs, Iridium tip or normal tip. Iridium are good for about 30- 40 k miles, normal about 10k miles. Eurocarparts sell both types, I've just fitted the Beru plug they list and they are fine. I removed the Bosch 4 prong "thing" they also list at about £5 each, also fine. Nothing wrong with the "normal" plugs at about £3 each, but if you hate doing the job maybe Iridium are for you, but expect £14 each per plug.
My main issue was the plug spanner as they are small plugs, motorbike size. Halfords sell a plug socket if you need one.
Easy enough job, just remember what order things go back.
Mike
Mike
Last edit: 14 Jul 2019 19:42 by Scimike.
The following user(s) said Thank You: barnsley john
- barnsley john
14 Jul 2019 20:21 #211067
by barnsley john
Replied by barnsley john on topic changing spark plugs s3 vvt 2017
thanks for the info will get some and change john
Time to create page: 0.078 seconds
