Front Axle Question.
7 years 4 months ago #210278
by bryn
Front Axle Question. was created by bryn
I may have to replace the front axle on my 2007 Jimny which has ABS. If the only axle I can source is one without ABS will if fit or must it be replaced with a one with ABS.
Thanks
bryn
Thanks
bryn
- Thank you received: 706
7 years 4 months ago #210279
Replied by jackonlyjack on topic Front Axle Question.
None abs will fit but abs system faults would be a problem on mot day
just send James aka J999pre a message he will have whatever you need
Jack
Jack
7 years 4 months ago #210290
by bryn
Replied by bryn on topic Front Axle Question.
Thanks jack. Ive sent James a message.
bryn
bryn
7 years 4 months ago #210305
Replied by Riccy on topic Front Axle Question.
The front casing should be OK as the ABS sensors attach to the swivels, not the axle tube itself. You would need to keep the ABS swivels on but I think the tube will be the same. The diff might well be the wrong ratio so best to swap that over as well.
Time to create page: 0.083 seconds
