Gearbox trouble
7 years 4 months ago #210265
by sniper
Gearbox trouble was created by sniper
My 05' VVT gearbox has died, personal circumstances mean I can't be without a car so I need to act quickly. The trouble is.....
Option1 Rebuild the box at a cost of £720inc. drop it off tomorrow and get it back next day with a free loan car...
Option 2 Fit R7ME box and matching transfer box only £250 in parts but means I've got to go to 235/75 to match the gearing so + £500
Option 2 is the preferred course but I can't get it organised in time.....
Can anybody help with other suggestions???
sniper
sniper
7 years 4 months ago - 7 years 4 months ago #210269
Replied by Riccy on topic Gearbox trouble
Oh no! :ohmy:
Option 2 would be my choice, but thats a fair bit more work. Dont forget you need to adapt the gearbox mount to fit into the vvt chassis
A solution might be to consider a cheap hire car/van to bridge the time gap perhaps? Some of the smaller local companies might be open to a good deal for a longer hire maybe?
edit: A 235 spare tyre on the back door will need a spacer to fit
Last edit: 7 years 4 months ago by Riccy.
- Thank you received: 2004
7 years 4 months ago #210272
Replied by Lambert on topic Gearbox trouble
I would second some kind of hire car for a week or so? Would give you some breathing space.
7 years 4 months ago #210295
by sniper
Replied by sniper on topic Gearbox trouble
I have an obligation to tend to my elderly Mother and with the wife's work schedule, I simply could not be without the car for the week or two it would take to get the parts & organise for the R7ME Swap.
So, M&T transmissions it is for the rebuild. They are familiar with the R72 weakness and stated that there would be no re-occurrence with the rebuild, the new bearings are sealed. £600+vat. Only £450 if you take the box to them as a bench job, the bearing kits are around £120, so not robbing you...
Fitting a new Excedy clutch too, the old LUK one gave no trouble (at only10k) but I thought that while it was apart, it was a wise move.
sniper
sniper
7 years 4 months ago #210318
by sniper
Very surprised when I collect the car this morning, it feels different to drive....
Gearbox throw has been massively reduced and it feels like the H pattern is tighter, almost like a short shift kit would do....
The Exedy clutch is a revelation too, firstly they've adjusted it properly and the biting point is very low in the pedal travel. The bite from the clutch is much more aggressive too, the distance between slip and bite is minimal. (I stalled twice)
The box itself is quiet and smooth.
To remove and rebuild the R72 gearbox, install a new Exedy clutch and refit gearbox. £827 including the dreaded VAT. from M&T Transmissions, Sheffield. Free loan car provided too. Don't forget that they do it as a bench job for £450+ for those of you who can do the spanner work yourselves.
sniper
sniper
7 years 4 months ago #210323
800 with a car, that's cheap!
Time to create page: 0.098 seconds
