Removing Rubber Bushes from Radius Arms
22 Jun 2019 13:51 - 22 Jun 2019 13:52 #210204
by raLLe
Last edit: 22 Jun 2019 13:52 by raLLe.
22 Jun 2019 20:12 #210219
by gv42
Replied by gv42 on topic Removing Rubber Bushes from Radius Arms
did the rear sticks today, easier with Press ,thanks for the guidance !
23 Jun 2019 06:23 #210220
by paul2u
Replied by paul2u on topic Removing Rubber Bushes from Radius Arms
i made good use of my hydraulic log splitter and pushed them all out and inn
24 Jun 2019 21:13 #210288
by kirkynut
Replied by kirkynut on topic Removing Rubber Bushes from Radius Arms
I just drilled holes all the way round the rubber, the rubber falls out and then cut the outer band with a hacksaw blade and knock the band out.
Fire is fun though!
Fire is fun though!
- Dirtbird
13 Dec 2020 14:49 #230884
by Dirtbird
Replied by Dirtbird on topic Removing Rubber Bushes from Radius Arms
Paul did you have to do anything special to make the log splitter work, a great idea by the way.
J
J
- mickt
13 Dec 2020 17:28 #230885
by mickt
Replied by mickt on topic Removing Rubber Bushes from Radius Arms
On the original post his hacksaw use to split the bearing resulted in it cutting into the arm as he overcut it. That can lead to the arm failing!
Time to create page: 0.214 seconds
