Front diff remove/repair
- Thank you received: 2004
14 Jun 2019 09:27 #209935
Replied by Lambert on topic Front diff remove/repair
Ok. So multiple impacts along the length of the car. Could be a lot of things. Have you examined the transfer box and its mounting points? A Jimny is a very short car and vibration travels easily especially when it is severe. Also check all the control arm bushes thoroughly, they should need a lever to obtain movement and be firm to the hand. Also check the main gearbox rear mount, if it is running the central prop out of line that might be enough. It could also be something as simple as knocking off the rear prop balance weight. You are going to have to be thorough and check everything closely.
14 Jun 2019 09:33 #209936
It would be prudent if you can safely lift all 4 wheels off the ground and switch it on with an assistant engage drive and look and feel what is wrong. Be very careful with doing this as the spinning bits of the car will show you no mercy as they try to kill you.
- Basketcase
14 Jun 2019 13:43 #209940
by Basketcase
Replied by Basketcase on topic Front diff remove/repair
Have you tried driving it with the front prop removed to try and eliminate any distortion in the front prop? Take the front hubs off too so the shafts in front axle also don’t turn and see if it still vibrates
17 Jun 2019 07:32 #210046
by kirkynut
Replied by kirkynut on topic Front diff remove/repair
Where are you based Gary?
- 2013gary
18 Jun 2019 09:37 #210077
by 2013gary
Replied by 2013gary on topic Front diff remove/repair
Thanks again for helpful replies.
@Lambert I have a transfer box guard which appears undamaged. Nevertheless I've removed it and had a look and everything looks okay. I tested all of the control arms by trying to move them by hand and I didn't notice any movement at all. I've had a good look underneath and everything *looks* straight and undamaged, although I only have limited experience when it comes to the running gear. I didn't notice anything that looked like a balance weight on the rear prop - is it an obvious thing to see?As for putting it completely in the air and driving it I'm not sure I have the cahonies!
@basketcase thanks for the suggestion I will try this next. Another silly question, is removing the front prop as simple as undoing all the bolts? Or are there other things that I should be aware of?
@Kirkynut I'm based in Tonbridge, Kent. If you know of or can recommend anyone around here that knows Jimny's well then I'd be very grateful!
Time to create page: 0.086 seconds
