Radiators
- Roseblade
7 years 5 months ago #209234
by Roseblade
Radiators was created by Roseblade
Hi folks,
I have just discovered my jimny's radiator has a leak (2008). Probably just down to age/mileage but before I go and source a new rad, is there any particular issues I should be aware of? I know that standard rads on many cars are built to minimum spec for the model.
Is there a common upgrade that might be worth doing? I should mention that I do a lot of towing and being in Devon there is no shortage of hills around here.
- Thank you received: 2005
7 years 5 months ago #209235
I have a nissens one in Dreadnaught. Just a standard replacement one, nothing special. Works well and I also do much hilly towing. Generally holds about 87 to 96 degrees and cools off quickly.
- Roseblade
7 years 5 months ago #209238
by Roseblade
Replied by Roseblade on topic Radiators
Thats great. I will look into that.
Thanks,
Thanks,
7 years 5 months ago #209240
I want to say it was about 70 to 80 quid from Andrew Page.
The following user(s) said Thank You: Roseblade
7 years 5 months ago #209387
by kirkynut
Yep, standard rads are fine. Just be sure the rest of the system is working well too, so the water pump and the viscous fan.
Time to create page: 0.091 seconds
