Gen4 front speaker upgrade
- Skinner
25 Jun 2019 13:04 - 25 Jun 2019 13:05 #210302
by Skinner
Replied by Skinner on topic Gen4 front speaker upgrade
Cheers from Finland! Picked up my Jungle Green Gen 4 yesterday and the speakers definitely need some upgrade, both front and rear. Thinking about DIY solution prior waiting for Suzuki parts to arrivive. Did any upgrader measure the height of the mounting bracket? Ie. How much space the speaker needs. And is the speaker wire plug a standard which I could pick from any car part dealer?
Any DIY options for the rear speaker brackets? My kid is yelling in the back for louder music and my ears are bleeding...
Last edit: 25 Jun 2019 13:05 by Skinner.
- Thank you received: 330
25 Jun 2019 16:12 #210303
by Gadget
Replied by Gadget on topic Gen4 front speaker upgrade
I didn't measure but would guess at about 20-25mm depth for the adapters. I believe the speaker connectors are standard across a lot of Japanese cars. These look identical aside from colour:
incartec.co.uk/product/Japanese-car-mode...peaker-cable-adapter
03 Jun 2020 07:37 #223191
by 1tamad
Replied by 1tamad on topic Gen4 front speaker upgrade
Warning! The Sony 13cm Xplod don't fit. They have a bigger diameter housing than the ring supplied in the kit. I had to use Pioneer 13cm speakers. I hope I can use the Sonys as rear speakers.
- RumbleAndSway
- Premium Member
- Thank you received: 12
04 Jun 2020 19:17 #223265
by RumbleAndSway
Replied by RumbleAndSway on topic Gen4 front speaker upgrade
Directions make the install a doddle. 30 minute job from unboxing to finish. Thank you.
Martin, your service, as ever, first class. Thank you
- mcgarnicle
15 Mar 2022 00:33 #242324
by mcgarnicle
Replied by mcgarnicle on topic Gen4 front speaker upgrade
Did you have any success installing the Sony 13cm Xplod in the rear?
- rogerzilla
19 Mar 2024 13:54 - 19 Mar 2024 13:56 #255174
by rogerzilla
Replied by rogerzilla on topic Gen4 front speaker upgrade
I'm planning to do this at the weekend. I have some Rockord Fosgate speakers (10 years ago, I fitted some to a gen3 and it sounded really good). The "basket" of the speaker sits in the adaptor just fine. However, the four mounting lugs, as with the Pioneer speakers shown above, are well outside the adaptor. The Pioneer has extra holes inboard of the lugs, but the RF ones don't. Is it a case of drilling through the speaker mounting flange?
I think one issue is that the adaptor is meant for 13cm speakers but most "13cm" speakers are actually 5 1/4", which is a bit bigger.
Last edit: 19 Mar 2024 13:56 by rogerzilla.
Time to create page: 0.262 seconds
