Axle Swivels
- partho00
22 May 2019 10:19 - 22 May 2019 10:31 #208653
by partho00
Axle Swivels was created by partho00
Hi all,
My wife has just taken her beloved Jimny (SuLu) for its MOT. It passed, but the garage have made quite a big deal about some pitting & corrosion on the front axle swivels. They have told her they need replacing and they ‘might’ last a year but they don’t know for sure.
I’ve had a look at them and to my eyes it really doesn’t look so bad. I’ve attached some pictures and wondered if anyone can advise on how serious the corrosion is.
The garage has advised that the who front axle will need replacing and cost £1500+ which seems a bit extreme.
Thanks in advance for you expertise and experience!
Tom
Tom
Last edit: 22 May 2019 10:31 by partho00.
- Thank you received: 2004
22 May 2019 11:47 #208657
Replied by Lambert on topic Axle Swivels
Welcome to the forum. Utter tosh. Those swivels are fine. Mine are much worse and not a problem. A lot of garages especially see that as a quick way to make money. I do notice a very slight bit of dampness on the bottom of one which is a early indication that the king pin bearings will need looking at eventually but that is fine. It is possible to strip them down and fill and paint them with a really hard epoxy paint but there's no real need. They are not an oil seals so don't have to be a perfect smooth surface.
The following user(s) said Thank You: partho00
22 May 2019 12:12 #208659
Replied by mlines on topic Axle Swivels
Yep -tosh
Garage is thinking "Landrover" where the swivels are chromed and form part of the axle sealing system, this is an MOT failure on landrovers.
Jimnys do not have sealed axles in the same way. Rub them down, fill the pitting and paint.
- partho00
22 May 2019 17:12 #208699
by partho00
Replied by partho00 on topic Axle Swivels
Thanks for the input guys! Much appreciated.
It was a specialist landrover garage so maybe that’s why they were so observant about the swivels. Either that or they just planned to make some easy money...
22 May 2019 17:51 #208719
by facade
Replied by facade on topic Axle Swivels
When I last did the kingpins I splashed out on new dust seals (which are about a million pounds each), so I sanded down all the rust with a flap wheel, and painted with enamel paint, but it took about a week to harden enough that my nail wouldn't mark it before I could put it all back together, lucky I have a 'bike to go to work on..
22 May 2019 19:39 - 22 May 2019 19:40 #208742
by Scimike
Replied by Scimike on topic Axle Swivels
I just want to type Tosh :laugh:
Yep what's already been said. Ignore it, keep a check on the kingpin bearing and find another MOT station for next year. To be honest some MOT stations will simply put advisory comments if they are not sure, its just to cover their a*s.
Last edit: 22 May 2019 19:40 by Scimike.
Time to create page: 0.124 seconds
